Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
The headphone jack isn't working properly
The headphone jack only allows the right earphone to work. I can jiggle the connector and it breaks up. How do I fix it? It doesn't matter if I change to different headphones... it still does the same thing.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Check to see if you have broken a tip off any of your headsets. It may be in the iPod and preventing full contact.
Was dit antwoord nuttig?
Score 2
This means that the headphone jack is becoming faulty and needs to be replaced. Simply locate the size of your iPod video and replace the headphone jack/hold switch. Very easy to do.
1 Opmerking:
What's the reason for the downvote? Sure, you should check the headphones out first. But this is a solid response.
door
Voeg je antwoord toe
SuzV zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,051
