Ga door naar hoofdinhoud
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
S21 ultra not recognizing usb device's
Why does my galaxy s21 ultra not recognize usb device's for file transfer or wired ear phones
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello,
Try taking a look at the settings. I believe there is a security setting for external devices. Try looking inside the privacy and security settings. If there are no settings causing this issue, there might be a issue with the USB C port. I hope this helps!
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
If I plug my tablet into my phone using the factory type c to c cable it allows me to charge my tablet but no file transfer
door
You need to activate developer options. You can do so by going to your settings-about phone-software information.Click on build number 7 times. This activates developer options. Go back to settings and scroll down till you see developer options then click on it. Scroll down till you see options for debugging. Click USB debugging to turn it on. This should allow you to transfer using your C to C cable.
door
@tia rose , thank you sooo much! It read as soon as i followed those steps. Appreciate u mann
door
Voeg je antwoord toe
timothy walter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 78
Altijd: 9,430
