Ga door naar hoofdinhoud
Repair guides and support for Panasonic's Viera line of televisions.
406 Vragen Bekijk alle
Panasonic Viera TH-P65ST50A 3D Plasma TV turning off by itself
“Hi I've got a Panasonic Viera TH-P65ST50A 3D Plasma TV (Built in 2012) which has recently started to shut itself off after 5-10 minutes and goes into standby mode with the red light blinking. I normally turn it off by the power button on the TV and then turn it back on. It sometimes does this another 2 to 3 times before it stays on completely. Can this be fixed?”
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hello,
Before assuming it is a physical issue, try taking a look at the settings. Does your TV have an OSD (On Screen Display)?
If it does, try taking a look at the Power and Sleep section, or something like that. If there is no luck tweaking settings, it might be a hardware issue and may require a teardown and assessment. I hope this helps!
Was dit antwoord nuttig?
Voeg je antwoord toe
David Michelon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 9
