Ga door naar hoofdinhoud
Phantom paper jam error message won't clear
Hi
My Epson ET-2800 series printer says there is a paper jam but there is not. I cannot get it to clear this message so it will not print anything.
Thanks
M
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Over time paper dust can collect covering the optical sensor so it thinks paper is jamming things up. Open the printer as you would for a jam and locate the sensor, a short blast of can’ed air should fix this. If not the sensor it’s self could have failed.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I tried the blast of air and it did not work. How do I fool the sensor? Where is the sensor in this model?
door
the model is ET-2803
door
@cmdoh - Here’s a similar printer Epson Printer Service Manual
You can’t fool the sensor, but you may need a replacement
door
Voeg je antwoord toe
cmdoh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 62
Altijd: 2,047
