Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3291 Vragen Bekijk alle
Dropped in toilet, Dried and Charged but it smoked
Is there any possible chance for my iphone to get repair. i accidentally dropped it in toilet then i tried to dried it and 2 days after i tried to open it and charged it but it smoked ( i think i have short circuit it ) can i still save my iphone4 at any cost? pls and thanks
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
2 Antwoorden
Gekozen oplossing
Ryan Richard Merencilla, the very first thing I would suggest is that you clean your iPhone. Use this as your guide It was written for a 3G but still will show you how and what to clean. Use these guides to disassemble your phone. After you cleaned your phone very well, change your battery. NO matter what, I always change the battery after any water damage. Inspect your iPhone for any charring on the logic board as well as charred solder connections, SMD components and IC's. If you find anything that looks like it may be damaged, let us know. Otherwise reassemble your phone and see what you get.
Was dit antwoord nuttig?
Score 1
If it smoked when you were charging it, you may have fried your logic board.
Commentaar:
Mark is very likely right, but at this point there is no harm in going into your phone and confirming that it's the logic board and maybe not some smaller part. Check out our guide here to remove your logic board and inspect it.
door
Voeg je antwoord toe
Ryan Richard Merencilla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 298
