Why does my sound work with Apple TV but not while using Roku?
Just hooked up my Sharp Roku TV to my reciver. While playing video On Roku it gives me this weird sound. But, when I use my Apple TV it works good. What could be causing this?
Is dit een goede vraag?
3 opmerkingen:
@simbaisaboy Can you record the sound from the reciever when playing something like Walk Through the Park(https://open.spotify.com/track/6RuyIcuaC...) (https://youtu.be/Fu5iMcEELaw) on the built-in Roku of the TV? Then, upload it here (as a video). You should be able to use the same instructions as Voeg afbeeldingen toe aan een bestaande vraag
door
Can you try to plug your Roku box into a different TV and see if the same issue occurs?
door
@simbaisaboy Also, are you using optical or something like HDMI ARC as your audio output to the reciever?
door
Voeg een opmerking toe
