Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
527 Vragen Bekijk alle
What's needed to upgrade storage on iMac 17,1 with SSD configuration?
Looking to upgrade a iMac Retina 5K with 4.0 GHz Core i7 (iMac17,1) that came configured with an Apple SM0512G SSD. I am planning to add a salvaged Samsung 850 EVO 2GB SATA SSD 2.5 inch. My questions follow:
1) System Report indicates an Apple SSD SM0512G on PCI protocol. Does this indicate the only drive is a blade NVMe in the PCIe slot?
2) Will I need any of the following components to successfully add the SATA SDD to the presumably-empty HDD slot?
a) SATA cable
b) mounting brackets
c) OWC thermal sensor
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The SSD that is currently installed in your computer is a blade drive installed in the slot on the backside of the main logic board. To install an additional 2.5-inch SATA SSD, you will need to de-adhere the display carefully, remove the logic board, install the appropriate SATA cable, route the SATA cable and reinstall the logic board, install the appropriate mounting hardware for the 2.5-inch SSD, install the 2.5-inch SSD, then reinstall the display using adhesive tape. The SATA cables for these machines should be able to handle the temperature (I've never noticed any problems after installing 2.5-inch SSDs and have never needed a third-party temperature sensor for these models). Hope that helps!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Paul Strasma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 29
