Ga door naar hoofdinhoud
A gaming PC is a personal computer specifically designed and optimized for playing video games.
32 Vragen Bekijk alle
My pc start for 1 second and turned off and start again
As i said after 20 days i turned on my pc ad he start but for some reason won't show any screen just black and there was a blue lamp that show is pc running normally now also the lamp won't start i tried many things for troubleshooting but nothing work
My pc configuration :
  • Amd Ryzen 3 3200G
  • Mother board Msi B450m a pro max
  • 16 gb ram hyperx 2660mhz ddr4
  • Nvidia gtx 1650super
  • Antec power supply 450 w 80 plus bronze
  • Hdd with system windows 10
  • Ssd empty
Is dit een goede vraag?
1 Opmerking:
What troubleshooting have you tried so we don't repeat what you have already tried?
door
Voeg een opmerking toe
1 Antwoord
We need to know what troubleshooting you've already done, but here are some tips :
  • Check if your CPU is seated correctly
  • Check for any loose cables
  • Check for any components that are loose (for example : the ram sticks not being fully inserted)
But, it kind of sounds like a CPU problem.
Also where are you getting your display output from? The GPU or the motherboard?
If you are plugged into the GPU, it could be a GPU problem too.
I doubt it is the motherboard though.
Try these, and tell me if anything worked.
Was dit antwoord nuttig?
Voeg je antwoord toe
Akhbar Mix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 47
