Ga door naar hoofdinhoud
Repair information for Sharp televisions.
101 Vragen Bekijk alle
Sharp 40BJ3K no picture or sound
My sharp LCD colour TV, Model 40BJ3K, serial no, C40UK7552KB65N 40181800700549, has no picture or sound. Whenever I click on standby, the light changes from red to white, I tried it in a different socket (my old tv is working fine in that one) tried in a darkened room, using a flashlight, varying angles but unfortunately I cant see anything but a black screen, it was working perfectly the night before & I live alone so I know no one has been anywhere near it. Any help is greatly appreciated. Thank you.
Feb 14, 2023 by Shirley-Ann Mills
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
@shirleyannmills since I do not see any schematics or manuals for your Sharp TV verify the model number for us. Not saying you are wrong but just wanting to make sure. Anyhow, the next thing you want to do is to remove the back cover. Unplug your power cord for that. With the cover removed, do a visual inspection and check for anything that may look "different" Missing components, charred components, leaking capacitors etc. are all things to look out for. If all of that looks okay you will need to test the voltage to the main board on the power supply. Since we do not have schematics, we will need you to post some good pictures of your boards with your question. That way we can see what you see and hopefully guide you further.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
Shirley-Ann Mills zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 32
