Ga door naar hoofdinhoud
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1192 Vragen Bekijk alle
Why my laptop charging on/off after hit 50% capacity battery?
I have been changes my laptop battery with a new one as the old battery cant hold for a longer time. Then, after the changed I notice the new issues when I want to charge my laptop the charging will suddenly on/off after the battery capacity hit 50% above. Can help me figure out what this issues caused by? Thank you
Laptop model: Acer Aspire P645-sg
Battery model: Acer AP12A3I battery
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If your system can only be charged to 55-60%, it may due to conservation mode or the custom battery charge threshold may be turned on. Use the following steps to turn off the function: Go to Device, My Device Settings, Battery. If you are using Lenovo PC, set conservation mode to off.
Regards,
Will
Was dit antwoord nuttig?
Voeg je antwoord toe
Shahrin Azuan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 39
