Ga door naar hoofdinhoud
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
325 Vragen Bekijk alle
LED n2 does not light up
Hello. LED n2 does not light up, what could be the problem? How could I check it? Is it necessary to have the ram and processor mounted on the motherboard for it to turn on? Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
andre.dias.tui you are looking at LED 1 which means you need to check LED Startup Sequence
LED #1 = Power available.
If LED 1 is on but LED 2 does not come on, you will need to check:
• Verify power button connection to logic board
• Verify power button functionality
  • Disconnect power button from logic board. Inspect cable and connector for damage. Verify continuity between the two pins of power button when it is pressed.
• Verify cable connection between power supply and logic board
• Verify power supply
• Verify logic board
I would start by checking the power board voltage output to the logic board. You can measure that on the power connector from the power supply.
Was dit antwoord nuttig?
Voeg je antwoord toe
andre.dias.tui zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 11
