Battery charger not working
Is dit een goede vraag?
Gordon Young that camera does not charge the battery. You will need a separate battery charger. Make sure that your battery is still capable of holding a charge. so you need to check your battery chargers in-voltage, and your out-voltage. If those are okay, I recommend to replace the battery.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 59
Hi,
If the charger is used with a wall plug power adapter, have you checked that there is 8.4V DC on the output cable plug of the adapter? example to show specifications of the adapter(s)
What have you tried?
door jayeff
