Why does my phone dies when unplugged from charger?
My phone only works when its charging. And took time before it start after plugging charger.
Is dit een goede vraag?
either
1) the battery is on its way out and should be replaced.
2) there's an issue with the lightning flex cable assembly which is not allowing the battery to charge and should be replaced.
3) there's an issue with the recharging circuitry on the motherboard, which is big trouble, as it will require microsoldering repair on the motherboard. your best bet is to get a fully charged battery installed in the motherboard so you can pull an itunes or 3utools backup to preserve the data then deal with the hardware issue.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 131
1 Opmerking
It’s probably on life-support
You need to replace the battery
door ismail ali
