Ga door naar hoofdinhoud
Reparatiehandleidingen en -informatie voor de Nintento Switch Joy-Con controllers.
165 Vragen Bekijk alle
My right joycon is not recognized horizontally
Hi,
Both of my right joycons cannot be used horizontally AND their sync light does not work. They do work fine when used vertically (either docked or wireless), but just cannot be used horizontally. Any idea what I could do?
Thank you!
Laurent
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It could be that a connection is loose inside of the controller. The accelerometer might also have a short causing it to short when turned on it’s side. I hope that will help you. πŸ™ƒ
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks! I've ordered a screwdriver to try and clean the connection, and possibly check if anything got loose.
door
So when i open the controller and use some contact cleaner, it partially works, from time to time. But not when it's close. So some connection is loose. Both controllers that have this issue are right controllers and still charge. I'm trying to figure out what exactly couod be wrong.
door
Voeg je antwoord toe
Laurent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 738
