Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
758 Vragen Bekijk alle
Playstation 3 not reading games
I have a playstation 3 model cechl with blu ray drive bd-410 with laser part kes-410a.
My playstation 3 no longer reads dual layer blu ray discs so uncharted 3 won't read. The laser also doesn't work on dvd discs.
In learning about how to take the drive apart to get to the laser, now the laser won't read any blu ray discs.
My question is should I replace just the laser or do I need to replace the entire disc drive?
The ps3 can still eject discs. It seems like a silly question to ask, months back, I had a ps4 that wouldn't read about half the ps4 games that I had and I replaced the entire drive, laser and all. That solved the problem. Does it matter with the ps3?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
PS3 or PS4, step 1 is to clean the lens(es). Qtip with IPA, gently rub on the lens(es), then use the other end to dry it off.
If that doesn't work, then you can look into replacing the laser assembly, which is generally cheaper than an entire drive.
Entire drive is an option, but you will need to either preserve your old daughterboard, or marry the new one.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Justin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 24
