Ga door naar hoofdinhoud
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
355 Vragen Bekijk alle
I put my phone in the charger, then the electricity shocked me, but I
I put my phone in the charger, and the electricity shocked me, and I started charging the phone with the same charger, but I did not touch the phone until I removed the charger, and after the days passed, the phone turned off by itself. Do you have a solution?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@loukman you did not tell us what you touched at the time you got shocked. The output of the charger is low voltage and you should not feel anything. If you did get shocked to the point that you felt it, you had some higher voltages. I suggest a new charger/charge cable and a new daughter board. Then re-evaluate. When you have your phone apart, don't forget to check your motherboard for any damaged locking components and change the battery as well. If you have anything on your motherboard that looks damaged, post some pictures of it with your Question. That way we can see what you see.
Samsung Galaxy S7 Edge Teardown
Voeg afbeeldingen toe aan een bestaande vraag
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Samsung Galaxy S7 Edge Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
2 opmerkingen:
I opened the device, I'm not a repairman, but I didn't notice anything burnt, but I didn't notice anything. I put my tongue on the two poles of the battery, and I didn't feel a current.
door
@loukman i would proceed with the original plan. You may need a voltmeter to test your phone but do get a new battery for sure
door
Voeg je antwoord toe
Belkacem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 26
