Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
Is dit een goede vraag?
6 opmerkingen
Did I spell Intellivision correctly?
door thelectronicnub
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
door oldturkey03
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
door oldturkey03
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
1 commentaar meer tonen
