Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
71 Vragen Bekijk alle
If dropped in fire and screen slid off could I get new screen and it w
My phone dropped in burning pile, when i finally realized what had happened, i dug in the ashes and found it, the screen just slid off phone. To my surprise, my phone is still working, i have been getting notifications, and phone is ringing. If i replace screen should that be all i need to do?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Wow, sounds like you're one lucky person!
It's definitely possible. You might find other issues once the display is replaced, like cameras or microphones, but I'm sure your display didn't appreciate the heat. If you want, edit some pictures into your original post and we can have a look at the internals to try and determine how likely you are to encounter other issues. But it sounds like the logic board at the very least is functioning as intended.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
How can i add pictures?
door
@rvservice you can click edit on your original question and there should be an option to attach pictures. There's a guide as well if screenshots help to visualize
door
@rvservice Oh wow! That’s not what I was expecting at all. It looks like some of the layers of the display came delaminated, but not all of them. I was expecting the display itself to have come altogether. But I suppose this makes more sense.
The Face ID assembly definitely looks a little worse for wear. I wouldn’t trust that to work for sure, even though I can see some parts firing off infrared light. If you’re feeling really adventurous, and have a pentalobe P5 screwdriver to remove the security screws at the bottom, I might try to get the rest of the display out and see what the internals themselves look like. At least you don’t have to worry about breaking the screen? Just be mindful of the battery.
I’m not sure how functional you want the phone to be. No Face ID or front facing camera is one thing, but phones have a whole lot of bits and pieces.
door
Voeg je antwoord toe
Shimmer Shine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 190
