MacBook Pro 2011 Won't boot from a internal SSD
Hi
My system will not boot if I put a Bootable SSD internal, the same SSD will boot from a USB enclosure, I have change the HHD Cable 2011 with one from Amazon and still no luck.
The system will boot fine from a 1.5t HHD internal or USB I can even boot from a SD card.
if I hold down the option key with the SSD internally the system sees it and the recovery drive but when I select it I just get the flashing folder..
so I have read that I should order the 2012 cable as it is much better then the 2011 cable.
any help wold be great
Terry
Is dit een goede vraag?
