Ga door naar hoofdinhoud
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
146 Vragen Bekijk alle
When I turn on my car it sounds like the engine is hitting something
When i turn on my car the engine sounds like it hitting something but when i go check its nothing after a few minutes it stops it had good oil amd everything is good all the fluids
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi steve,
I did some checking and apparently your car most likely has a timing chain rather than a belt. I used to work at a Datsun dealership where all the cars had timing chains and the first time I heard a loose timing chain I knew exactly what it was; the sound was unmistakable. Over time the chains stretch until the combination of that and the tensioner getting worn down allows enough flex in the chain that it rattles.
You won't be able to tell for sure on your car unless you take off the timing cover and examine the chain. It should be taut with no slack in it at all; if there is, that's most likely the source of the noise you're hearing.
To get any more detail on your problem, it would help a lot if you would add information about the year and engine size of your Grand Am.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 17
