Ga door naar hoofdinhoud
Repair documentation and service information for Hisense televisions.
126 Vragen Bekijk alle
Red Blue And Green Horizontal Lines on Roku TV (onn.)
I have colored horizontal lines on my Roku 50” 4K Smart TV (onn. [wasn’t a device option]
Some lines are stationary, while other flicker between vibrant and faint
They show up better on certain (usually brighter) colors
And are faint and barely visible on other, (usually darker) colors
As for solid colors…
On Red, the lines are blue and yellow.
On Pink the lines are blue yellow and a bit of white
On orange the lines are blue and yellow
On green the lines are blue and red with a bit of fainter grey
On blue the lines are dark red (almost black) and yellow
on yellow the lines are red green and blue
On purple the lines are cyan and dark red
When watching tv or playing games, they are usaully not that noticeable but when you notice it, it becomes very annoying.
What causes this? And most importantly how do I fix this? (Or can I?)
Is dit een goede vraag?
Score 1
2 opmerkingen
@spencerc22 we have to see what this all looks like. Horizontal lines are almost exclusively a problem with the LCD panel. Post some pictures with your question so we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
door
@oldturkey03 they should be there now, just added
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@spencerc22 that looks like a driver board issue. Either a bad gate driver or a bad board. The driver boards are the boards that are connected to the panel via small ribbon cables. They are non-rrplaceable. Of course check for a burned or otherwise damaged component on those boards as well as loose connections etc. Ultimately looks like a bad panel
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
So just check if they are loose, but if that doesn’t work. just sell it as damaged screen (good for parts)?
door
@spencerc22 that's about all you can do. Or just use it as a spare somewhere....
door
Now when you say check if they are loose, do you mean the ribbon cables?
door
@spencerc22 yes, that is what i was referring to :-)
door
Voeg je antwoord toe
Caiden Spencer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 126
Altijd: 1,305
