Ga door naar hoofdinhoud
Hasbro released this Furby model in 2012. Furby is intended for young children and up to young adults.
17 Vragen Bekijk alle
Can I fix this furby?
Recently got a second hand furby boom from 2013. The seller claims it worked when he had it . So the furby reacted to noises, even if it didn't talk .But after a while it went instantly to sleep, the speaker is broken and I smelled a burning smell, one battery melted.
Would fixing the speaker help?? Is it battery corrosion?? Somone help.. the seller is really stubborn. Could it be some kind of battery corrosion
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Since the furby reacts to noises, all the sensors work, but the speaker is mute. And after a while it went instantly to sleep. The speaker could have something to do with it, I advise unplugging the speaker from the circuit board and seeing if the furby will stay on and not go to sleep instantly. If this works, then the speaker has something to do with it and will need to be replaced.
Here is a guide on how to replace furby's speaker: Hasbro furby 2012 Speaker Replacement
Here is a video on how you can repair the speaker in 3 different ways: https://youtu.be/Xn5a07DFh9k
Most furby speaker specs are 32 ohm, .25 watt, 40 mm. Since you smelled the speaker burning it could have something to do with the rest of the furby not working, I advise removing it anyways since you don't want it overheating.
This video of mine may help: https://youtu.be/UteznTOUegE
You said that one of the batteries melted, but in the photos the battery terminals are clean and show no sign of battery acid or leaking. If any corrosion is found, clean it away with isopropyl alcohol and a q-tip. If the furby keeps shutting off, and if the furby is unable to move then the small 6V brushless DC motor needs replacing.
Here’s a guide that may help: Hasbro furby 2012 DC Motor Replacement
You could spin/jumpstart the motor or lubricate it. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor.
Once you get the 6V DC motor, you’ll need to solder it on the pre-existing motor wires...I hope this helps, Thanks!
Hasbro furby 2012 Speaker Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 minutes
Hasbro furby 2012 DC Motor Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
25 - 30 minutes
Was dit antwoord nuttig?
Score 3
Hi
At the moment replacing the speak is unlikely to help
Your best bet would be a fully disassemble the furby and keep a eye out for any corrosion as these furbys are extremely prone to it due to them being able to use battery’s that can leak
If any corrosion is found ,clean it away with isopropyl alcohol and once fully clean carefully clean it again with distilled water(the distilled water will neutralise anything that’s too alkaline or acidic)
After that reassemble and see if the issue persists
If you see anything you are unsure of let me know any il try my best to help with it
Hopefully this helps
Any questions please ask
Score 1
2 opmerkingen:
Thank you, I will try that hope I can fix it .
door
@zuzsuz good luck!
door
Voeg je antwoord toe
Zuz_zed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 256
