Changed battery in 3GS, getting error 29 even with 0435 battery D:
I wiped my 3GS and installed a new battery (the original battery's APN: 616-0431), but as I was trying to install the latest iOS, the phone started rebooting every few minutes.
I took the new battery out and tried a *different* new battery, but I found myself faced with a persistent error 29. I tried:
- Using iRecovery to issue a 'setenv auto-boot true' command
- Holding down the home button while plugging in the USB cable
- Clearing out the hosts file
Finally I found one of iFixit's error 29 threads and assumed that I must have the wrong battery, so I ordered an iFixit battery with APN: 616-0435.
No dice, unfortunately. I can't get this thing to work. Do I need to jailbreak it or something? I've seen several forum threads mentioning redsnow and pwnagetool, but I've never jailbroken a phone and have no idea where to start.
Thanks in advance for any help you guys can offer.
Is dit een goede vraag?
4 opmerkingen
reidman, try iRecovery first and see if you can kick your phone out of the recovery loop. Download it from here and follow the instructions. Hope this helps, good luck.
door oldturkey03
I appreciate the tip oldturkey, but unfortunately I already gave that a shot -- no luck :(
door reidman
I am sorry, I did not realize you had tried that already. In that case definitely follow what pollytintop suggest. Good Luck and let us know how it turns out.
door oldturkey03
Apple are at fault with this and many problems error 29 had this and still have replaced battery with genuine apple same problem so its apples fault They say contact apple support rubbish the answers they come up with dont work it is a built in apple firmware problem that apple should sought out
door Micky hilto
