Ga door naar hoofdinhoud
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
My horn doesn't work
2017 Ford Fiesta SE horn does not work I couldn't find anything on the manual about horn.
Do you have any idea?
Thanks
Is dit een goede vraag?
1 Opmerking
@eokay can you get to the horn? Do you have a test light? Checked the fuses? What else have you checked?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@eokay check the Fuse F38 in the fuse box under the hood. It'll be a 20A fuse. See if that is ok. Next remove the cable off the horn and test it with a continuity light meter. You can get those at Walmart/ Harbor freight etc. Inexpensive but valuable tool. Check if it lights up when you push the horn button. LAst but not least your could just apply direct power to your horn. If it works, you know its your wiring/relay/fuse. If it doesn't it's your horn.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
ekin okay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 24
Altijd: 1,183
