Wiring issues 405000x8g b&s 21b8070296e1
I already have that manual and it still won't go ive replaced carburetor spark plug starter
The orange wire where does it go on the ignition. Since I have no safety switches and what about the yellow there is no ground on starter or stator am I suppose to add one? Also the stator wires are red and black should I put them together and what letter o. The key switch do they go to? How do I wire if I don't have the big diode that comes from magneto,lights and fuel solenoid.
Is dit een goede vraag?
2 opmerkingen
No I am not an experienced electrician but I've been working on this lawn mower everyday for 2 to 3 months I've been watching video after video on how to rewire a riding lawn mower per the videos that I've watched the black wire coming from the Stater is used for lights is that correct or is the black wire coming from the stator or ground thank you so much for your information it really helped I was putting a ground on everything because that's what it showed in the diagram of course I have a digital multimeter
door Michelle Depew
@Michelle Depew In DC circuits on small engines, black is always GND (sometimes also referred to as negative). The stator should have (at least) two wires: black and red. Black is GND and red should be positive (12V). In charging, 12V is actually somewhere around 13.5-14V.
Then you just have to use the DMM to trace your wires. The bare necessities of the circuit is GND (negative on battery) via a short, thick and black wire, screwed to the chassis. Then from the positive on battery (12V) via a switch (ignition switch) to the starter solenoid (not the starter). Then again from the starter solenoid to the actual starter. The service are all red (positive) as the GND is taken care of by being screwed to the chassis.
NB! There are exceptions to the GND, where there are wires for the GND, but that’s usually if there has been modifications done.
door Geir Ove Andersen
