Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Is dit een goede vraag?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Was dit antwoord nuttig?
Thanks
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 284
7 opmerkingen
Is this a necessary component?
door Brad
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
door Arnoud
do you mean on back of motherboard or on inside of rear case???
door pollytintop
Inside of rear case behind battery....
door Arnoud
Slide 30 in changing the rear case gives a good view.
door Arnoud
2 commentaren meer tonen
