Corsa VxR repair manual
Dead cylinder 4 unsure why. Rough idle running, zero compression in one cylinder and low in the rest (8 bar)
Is dit een goede vraag?
@hamzamsj this "zero compression in one cylinder and low in the rest (8 bar)" needs some serious work. You do need theck your valvetrain and your Pistons, head gasket etc. as well as multipole other things. Do a leak-down test and see what that reveals. A compression of zero will cause all the other symptoms you are referring to. Anyhow, I am certain a manual will be available but you need to let us know what exact year and engine size your VXR is.
Was dit antwoord nuttig?
It’s a 2013 VXR Nurburgring edition. It’s turbocharged and has a A16LER engine which has a relatively low mileage at 74k
It’s a 1.6L manual engine
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 135
