Ga door naar hoofdinhoud
Repair information for the game cartridge used for Gameboy Advance games, also known as the AGB-002.
Pokémon Emerald Game Problem
So I bought the Pokemon Emerald cartridge(The previous owner glued a new battery with tape...). When I started the game I've noticed that the start screen logo was messed up also some other graphics were missing from the game. For instance I couldn't see the three pokeballs in the beginning when it was the time to choose my first Pokemon. As soon as I saw that I've opened the cartridge and found some corroded pins and traces(Some of them missing). The RTC IC had a missing and corroded trace.
I've cleaned them and re soldered the Rom and Flash Ic's, but nothing changed. Could it be that the ROM is faulty or something else?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
I would do over all the pins and make sure there aren’t any loose pins at all
Also keep a eye on the vias as they can have corrosion inside of them and check for any broken traces or anything that looks off
If the board has no more issues it could be a corrupted data on it
As a guide I suggest you watch this video as it shows a lot of the faults that it could be
https://m.youtube.com/watch?v=xYUW0uVBp0...
If you still can’t find anything feel free to add some more photos of the whole board using this amazing guide
Voeg afbeeldingen toe aan een bestaande vraag
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Kostas Goldenmouth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 911
