Ga door naar hoofdinhoud
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 Vragen Bekijk alle
PSP go wont turn on.
I recently got a PSP go. I've had it for a week and not dropped it once, infact i've babied the thing because it's so thin and light i was worried i'd break it(go figure). It fell out of my pocket when i was kneeling and hit a hardwood floor and landed on a blanket afterward. after picking it up and checking for cracks i tried to turn it on and nothing happened. i plugged it in and the charging light came on for a second then went off, and it still wont turn on. Any ideas what messed up and if it's fixable? I think it might be the battery coming loose although without any jewelers screw drivers to take it apart yet with.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You've got the right idea Vince. The battery would be the best place to start and is a likely culprit for your issues. See if you can get your hands on a plastic opening tool and Phillips #00 screw driver and use this guide to help you get into your PSP. Good luck and let us know what you find.
Was dit antwoord nuttig?
Voeg je antwoord toe
Vince zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,570
