Ga door naar hoofdinhoud
De grotere versie van Samsung's nieuwste smartphone, de Samsung Galaxy S8 Plus. Uitgebracht in April van 2017.
167 Vragen Bekijk alle
Moisture in charging port, fast charging not working anymore
Ever since I got the moisture in the charging port notification, my fast charging doesn't work anymore. When I plug in the charger it shows fast charging and first then makes a second beeping sound and changes back to cable charge and also my phone doesn't charge when it's switched off anymore, only when it's on. Please what is the issue because I'm about to change the charging port board and I wanna be sure that's the issue so I don't waste money. So please help me out
What can be the issue here as I don't have any money for a new phone right now
Is dit een goede vraag?
Score 1
2 opmerkingen
Hi
Just adding to the amazing answer from @guardian10
Have you tried cleaning your charging port out with some fine tipped tweezers and some isopropyl alcohol
door
Yes I have tried cleaning with a tweezer but without alcohol though
Is the alcohol necessary?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Changing the charging port is likely needed.
Samsung Galaxy S8 Plus Charging Port Replacement
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Emmanuel Ufot zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 251
