Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
Replacing iPhone earpiece speaker; lost a Phillips screw. Will it work
I was replacing my iPhone 11 earpiece speaker and I lost a Phillips screw that holds the assembly inside the phone. Will the speaker still work or will it have issues if only 1 screw is missing from the assembly?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi
I think it will work fine as the speaker has separate connections and doesn’t use the screws for anything apart from holding itself to screen
I would replace it if given the chance though but it should work without it
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 1
It will most likely work, but if you are worried about it you could try to find a replacement screw. You can buy the sets of all the screws on eBay and a bunch of other places. Also make sure you replace the water proof seal when you finish the repair.
Score 1
Voeg je antwoord toe
Juan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 266
