Ga door naar hoofdinhoud
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 Vragen Bekijk alle
Floor shifter lights up wrong gear.
Transmission has been rebuilt. Shifts great! It just lights up wrong gear. Unless I can get the light in park (P) or neutral (N) it will not start. I need to bypass safety switch or fix whatever lights up gears.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like you may have 2 separate issues going on here. 1: your shift cable needs adjusted to show the correct gear. And 2: you need to check the safety switch. That should be mounted on the transmission, so the light indicating the gear shouldn't have an effect on that. Is it properly connected?
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jeffrey Frye zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 28
