Ga door naar hoofdinhoud
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
49 Vragen Bekijk alle
Touch not work after watchos9 digitizer refurbished
Hello people, i am fixing apple watch i am replacing the broken glass and puting the new one, so i have 2 apple Watches series 5 i have replace the both digitizers, and after watchos9 the touch works ony in half a screen and actually the watch is unable without touch, i have try to restart, i update to watchos 9.1 beta if that fix the issue nothing, does anyone knows a solution?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I don't know if this is related, but on the iPhones when updating to iOS 16 it would cause aftermarket soft OLED screens to have touch issues on the iPhone 11 Pro Max. and aftermarket hard OLED screens to have no image on the iPhone 12 Pro Max. This was apparently caused by a new boot process introduced on iOS 16. There may be a similar issue with watchOS 9. I wouldn't be surprised since this is definitely something Apple would do.
The only option for the iPhones with problems was to downgrade OS or change the screen with a different quality. This could be the case with the watch, although I do not know how to downgrade with an Apple Watch.
Of course you may just need to try different digitizers in case you happened to just have two go bad on you.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Sadly, at the time it is impossible for an end user to downgrade WatchOS without Apples proprietary tools that are not avalible.
door
Guys i still have this problem, everytime i fail to seperate the official touch from.the glass, the after market digitizer doesnt work on watchos 9, has anyone figure any success?, i have 5 apple watch screen and waiting cause of this New watchOs
Voeg je antwoord toe
Stelios K. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 154
