Ga door naar hoofdinhoud
The Magnum name was revived in 2004 as a 2005 station wagon on the Chrysler LX platform.
2 Vragen Bekijk alle
When I go to start my magnum it cranks but won't start.
I have a 06 magnum with the 2.7 has 128000 miles and when I turn the key it will crank but will not start. W as driving on day and it just died and would not restart just cranked. Any advice would be great I drive my 96 ram but the magnum is a lot cheaper on gas.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Can you hear the fuel pump running when you turn the ignition key onto the "On" position, before trying to start the engine?
To get fuel to the engine the PCM needs to get good signals from the crankshaft position sensor (CKP), the camshaft position sensor (CMP) and the ignition system so that it can operate the fuel pump relay to turn on the fuel pump.
If you can't hear the pump maybe check if you can hear the relay click. Bit hard if you're on your own of course ;-)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I’m starting to diagnose this issue just today. I’ve already checked relays. I’m going to be listening for the fuel pump here in a second and tapping at it a bit while someone cranks to see how it goes. 🙏
door
Voeg je antwoord toe
Clay Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 70
Altijd: 609
