Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Apple Watch Series 1 is een vernieuwde versie van de originele Apple Watch, aangekondigd op 7 september 2016. De meeste onderdelen zijn hetzelfde als die van de Series 2
Replacing Apple Watch Screen & Force Touch Sensor
Hi - I’ve tried once, and the screen would not adhere permanently. Does anyone have advice on the best steps to ensure the screen stays adhered? I cleaned all surfaces well with alcohol before and it still did not stay adhered. I see there are two adhesive gaskets included with the kit. Should I try to use one - first before the force touch sensor, on the Watch body, then the FT sensor, then another adhesive on top of that? Not sure if this will add too much thickness.
Any other suggestions are welcomed. I have another Ft sensor arriving today in the mail and want to get it right this time.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
https://youtu.be/s5-5pGfRgVc
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the response but this doesn’t answer the question I asked. I’ve watched all the ifixit videos already and followed the proper steps. The screen won’t adhere. And, I’m not the only one experiencing this.
My question was why they included TWO extra gaskets, and it it’s possible / recommended to use one first before the FT sensor and then another after the sensor - to help ensure the screen doesn’t pop off again.
door Deel
There are two adhesives, they go either side of the force touch gasket. One sticks the gasket to the watch and one sticks the screen to the gasket. Don’t worry about thicknesses.
door Deel
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 42
Altijd: 499
