Ga door naar hoofdinhoud
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Vragen Bekijk alle
Where are the Diagnostic LED's on a EMC2105 iMac?
I have a iMac emc 2105 20" model that will not power on. I have removed the case cover and am trying to locate the diagnostic LED's . There does not appear to be any LED's just to the right of the ram slots visible.
Where are the Diagnostic LED's and what do I have to remove to locate and see them ? I have found numerous references to other models and the diagnostic LED's but not this model.
I have found what might be a LEd on the "bottom" of the unit to the right of the RAM slot, but this is what might be a single LED, certainly not a row of 4 of them are present.
My real problem is that the machine will not power on and I am trying to diagnose whether it is the power supply or the motherboard.
Does this model have a SMC reset button ? If so, where?
Does this model have a internal power on button. If so, where ?
I was hoping to reset the SMC before I went any further -- how do I do that.
There is NOTHING glowing anywhere that I can find. I have not removed the back cover, only the front bezel and screen. I have replaced the backup battery ( Cr2032 on the motherboard). I have tried cmd+option+shift + pwr button reset -- -to no avail.
A pointer to a previous thread that answers this question and provides diagnostics for THIS model would be helpful.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You're looking in the right place. They may be covered up by a small piece of black tape that comes up from the bottom edge of the logic board. See if you can locate the tape and remove it.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Paul Lodrige zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 1,406
