After 25 years from the introduction of the first-generation Range Rover, the second-generation Range Rover—model-designation P38A—was introduced for the 1995 model year, with an updated version of the Rover V8 engine.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
1 Opmerking:
Test for actual spark on spark plugs and whether or not fuel is seen or smelled on plugs after failed starting attempts. Check for blown fuses as lack of fuel or spark narrows the problem down to one or the other. However, the lack of both may point to the crank position sensor as it generates timing signals the ecm needs to operate the entire EFI system.
door F Dryer
