Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 Dying at 4% after battery replacement!
I have an iPhone 6 and it randomly started to bootloop.I knew it was a battery issue, So I went into battery health and it was just loading.So I went to the same place I got my phone battery replace and they replaced it again.Everything was going great until my iPhone was at 4% and it randomly died.I plugged it in but instead of showing the low battery logo it showed the apple logo and it was at 4% instead of 1%.What should I do?
Is dit een goede vraag?
1 Opmerking
Have You calibrated the battery?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try calibrating the battery
Run it down until it shuts off,
Then charge it up to 100% uninterrupted then keep it plugged in for 2 more hours,
Run it down till it shuts down,
And finally, charge it uninterrupted to 100%
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
I was going to mention calibrating the battery as above but I’d run it down to 10% and then charge again rather than letting it die. But do what @beanman56 says.
door
@strongbow - It’s very necessary for the calibration to be done completely as it’s said,
Otherwise it’s probably gonna be the same
door
To be honest, they don't need calibrated at all. Calibration was for the old nickel based batteries. The newer lithium based batteries don't need calibrated. They are basically plug and play. I wouldn't worry about dying at 4%, it should work itself out over a few charges.
door
@strongbow - Then explain why ifixit says to calibrate the battery
door
Ask them? I’m not trying to explain someone else’s mistakes.
https://discussions.apple.com/thread/789...
door
2 commentaren meer tonen
Voeg je antwoord toe
Keshawn Vasugan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 80
