Ga door naar hoofdinhoud
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
368 Vragen Bekijk alle
Why is my phone half screen only when it gets light
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If your phone is cracked, chipped or broken then it's a obvious one if none of the problem is there then try the following.
  1. Check and compare the temperature on non working half and working half. if it's same then it would be a problem with sheet pasted under glass.
Was dit antwoord nuttig?
2 opmerkingen:
After it was hitten on the middle part of the screen the bottom half of the screen only shows only white color when its on until i flash a beam of light In the sensor part
door
You’ve answered your question. Hitting the screen on the middle has damaged it. You need a new screen.
door
Voeg je antwoord toe
adane mulugeta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 53
