Ga door naar hoofdinhoud
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
156 Vragen Bekijk alle
System powers on when power cable is connected. It can't be shut off.
The system will power on and not shut off. I swapped power supplies, and power button. Nether worked. I disconnected the power button and plugged in the console. It powered on. What can I do to fix this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Have you tried a hard reset? Press and hold the power button for around 10 seconds and see if it helps.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
No this didn't work
door
Short of replacing internal parts you can always unplug it or connect it to a switched power strip.
Score 1
1 Opmerking:
Ya. Well I'd be fine with replacing internals if it didn't seem to be a motherboard problem. But if the power button is held then the ejection button is pressed it shuts off normally
But it has to be timed to let your fingers go right away or it will power back on and eject the tray
door
Voeg je antwoord toe
David Staffen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 45
