Ga door naar hoofdinhoud
The Acer Aspire R7 is a touch screen laptop with a unique Ezel hinge and touchpad placement. This model was released in early 2014 as an updated version of the base Acer Aspire R7.
2 Vragen Bekijk alle
Screen replacement acer r7
Hi! Are the screens of r7 571 and r7 572 equal?
I have an acer r7 572 and usually finde only screens for 571. Are the models compatible?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
They have different part numbers, though I can't say they wouldn't be interchangeable. I would think the 571 screen could be used unless the bevel is significantly different, which could impact the seat of the replacement. Attached are image specs of each screen.
If you search r7 572 screen on Amazon, there are some options available there (I saw one for $67) that say they are a proper fit for your device.
Was dit antwoord nuttig?
Voeg je antwoord toe
thais_dill_enburg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 78
