Replaced Logic board, worked for a couple months, battery now dead
I needed to replace my logic board as the original one had issues (https://developer.apple.com/forums/threa...) and was successful in doing so.
I used my MBP for a couple months post install and it worked great. Just recently, the battery life has been nonexistent and needs to be plugged in via USB-C or the laptop will shutdown.
coconutbattery reports:
- Current Charge: 0 mAh
- Full charge capacity: 208 mAh
- Design capacity: 3.1%
- Cycle count: 152
- macOS Battery status: Poor
I double checked the contacts from the logic board to the battery controller and it looks ok to me. I can confirm that the battery isn't charging since I checked it with a multimeter and it showed around 2V.
My suspicion is that the problem is with the (new) logic board -- anyone else think so too?
Is dit een goede vraag?
Can you post the CoconutBattery screen so we can get the rest of the info. Voeg afbeeldingen toe aan een bestaande vraag
I would stay given the age of your system you may just need a new battery.
door Dan
Question edited with image. I don't think the battery itself is of issue since it retained charge normally before I replaced the logic board. Maybe the battery controller?
door aluminum robot
