Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
580 Vragen Bekijk alle
Is there a repair guide for MacBook Pro keyboard & power button
I recently did a repair for both speakers & both fans but when I put everything back in its place the power button & keyboard are not working & I can't reset the smc etc there another way to fix this problem?
Is dit een goede vraag?
3 opmerkingen
This question was migrated from https://meta.ifixit.com/Answers.
door
Benjamin, in order to help you out, we'll need a little more information.
What year and model is your MacBook Pro?
door
@dadibrokeit MacBook Pro Mid 2012 unibody
2.6 Ghz Quad-Core Intel Core i7
16GB 1600 Mhz DDR3
MacBook Pro 9,1
A1286 EMC 2556
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Benjamin,
Okay, so you had to pull the motherboard to get to the left speaker, which means you had to unplug the keyboard.
Now I'm not an expert on the MacBook Pro models, but on the regular MacBooks, the power button is basically just another keyboard button that gets a little special treatment for power on and off. So if the keyboard isn't plugged in, the power button won't work either.
It rather sounds to me as though the keyboard connector may not be seated correctly; with those wide thin flex cables it's easy to get them off by just a hair and they don't work. So first thing to do is open it back up and carefully check the keyboard ribbon cable. Pull it out and clean it with some isopropyl alcohol, verify there's no damage to the cable or the connector. Carefully reseat it in the connector, making sure it's inserted fully into the socket before you flip the latch.
With any luck that's all it is and you'll be back up and running in no time!
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Benjamin Matila zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 39
