Ga door naar hoofdinhoud
The OnePlus 7T is an Android smartphone from OnePlus. It was released in October 2019.
24 Vragen Bekijk alle
Forgot pin, unable to unlock the phone
Could not unlock the phone since I forgot the 4 digit password. I restarted the phone, so fingerprint option ain't available.
Is dit een goede vraag?
Score 6
3 opmerkingen
Restarting as in resetting this phone back to factory default as if new? If not then there may be a factory reset procedure that may erase all data to start as if it came from the factory. Either owner's manual or online tech support should have procedures. Online support should have guidance. ANd maybe a phone number for support too.
door
I have one plus 7 phone… I forgot the 4 digits password please help
door
I have lost my oneplus 7T and it was locked with PIN.
can the thief reset my phone and use it again ?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Unfortunately this will need resetting. Follow these steps and you should be good to go. Please give me an upvote if this helps👍
  1. Power off your OnePlus phone
  2. Press and hold the VOLUME DOWN and POWER buttons until the OnePlus logo AND a pattern dot screen appears
  3. Select FORGOT PASSWORD
  4. A data loss warning will appear on the screen; select OK and confirm your selection
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
I am sorry bro… I try what you told me but it never give me any option to pick
door
Thank you. It worked!
door
door
You have several possible solutions,. this page explains how to proceed. Good luck.
Voeg je antwoord toe
som mishra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 35
Afgelopen 7 dagen: 188
Afgelopen 30 dagen: 845
Altijd: 22,041
