Switch Lite will turn on but power button is unresponsive
Hello!
I’ve tried to research my issue but have had no success.
I bought a switch lite listed as “does not turn on”. Opened it up and discovered corrosion damage. After a gentle scrub of all the components it turns on! However, the power button will not work. The volume buttons work, but not the power.
- I bought a new ribbon cable - same issue, volume works, not power
- I swapped the motherboard with a working switch with working power button, same new ribbon cable - same issue
- Swapped physical power button and the membrane with a known “working” lite - same issue
The only thing I can think of is a warped shell that’s not allowing proper contact with the ribbon cable. What are your thoughts? I’m stumped. Especially with the motherboard swap.
Thank you in advance
Is dit een goede vraag?
15 opmerkingen
have you tried it just connected to the board and not in the housing ?
door daniel
@tech_ni I haven't, which is a great idea. I'll try it out when I get home this evening. Thank you!
door Rachel J
@tech_ni I tried it without the housing but with the membrane/buttons and it still doesn’t work. Volume buttons work fine.
door Rachel J
@racheldanger27 maybe a damaged trace near the connector or a failed resistor due to the liquid damage
door daniel
@tech_ni that would make sense for the corroded motherboard, but I'm stumped on the second motherboard. The second one had never been opened and showed no signs of water damage.
Also, I am very amateur at switch lite repair. Is this something that I could potentially fix once I get better at soldering? Replacing a resistor or connector?
Thank you so much for your help, daniel. I appreciate it.
door Rachel J
10 commentaren meer tonen
