Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
My iPhone doesn’t record voice notes or call
Hi
My iPhone 7 plus fell on the ground yesterday while I was recording a video, after this the video started to give a buzz sound at first and then and it records videos but with no sound after that I’m not able to record any voice notes, or even call
I tried to use earphones but the phone doesn’t recognise it even a wireless one the phone recognised it but doesn’t record or call
Also so many things are messed up in the software and the phone is acting strange ex: sometimes doesn’t press on video record button, instagram bugs sometimes doesn’t save the story etc
I just need to know if it is a mic issue or a software issue
Is it possible that falling on the ground causes software issue ? And if its a mic issue why still not working with a wireless headphones
Is dit een goede vraag?
1 Opmerking
Possibly something has gone wrong with the logic board? If there is an issue I think it would cause glitching while trying to use the phone, and it has stopped the phone from recognizing microphones?
I wouldn't think it would be the microphones, because it doesn't even work with wireless headphones. Have you made sure that those headphones you are using have a microphone?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
First thing I would do if you have not already is restart your phone. Software problems generally don't appear after a drop, unless it caused power to become disconnected when the system was making a change to something in storage.
I will note, the iPhone 7 and 7+ have a known and well documented issue regarding the Audio IC (the chip on the board which handles audio functions). There are a few connections under that chip which tend to become loose or disconnected altogether, generally due to flexion of the device/board. But a good hard drop could definitely make this worse. It's not a super typical presentation of this. Typically bluetooth headphones would still function with that issue, but I wouldn't entirely rule it out as a factor.
Was dit antwoord nuttig?
Score 1
Hi! Were you able to solve the issue? What was the problem?
2 opmerkingen:
Yes. As far as I can remember it was an Ic audio issue and got fixed by a technician
door
Regarding whether it's a mic issue or a software issue, it's difficult to determine without a thorough inspection. However, given the symptoms you described, it's likely a combination of both. Falls can result in hardware damage, which in turn can lead to software glitches.
door
Given the symptoms you described, it's likely a combination of both mic and software issues. Falls can result in hardware damage, which, in turn, can lead to software glitches. Since it's been two years, I hope you've had the opportunity to get your iPhone checked, but if not, it's still worth going to a certified Apple service center or technician. For additional insights on iPhone issues, you can visit applevox.com. They have updated information and tips that could be helpful.
Voeg je antwoord toe
Mariam Osama zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 333
