Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Jeep Cherokee is een voertuigenlijn die door Jeep in verschillende voertuigklassen wordt verkocht. Oorspronkelijk verkocht als een variant van de populaire Jeep Wagoneer, is de Cherokee geëvolueerd van een full-size SUV naar een van de eerste compacte SUV's en uiteindelijk naar de huidige incarnatie als een crossover-SUV.
Where Do I find these 'discs'?
Hello, my key fob pad recently broke and the metal discs allowing me to use the fob functions fell out and are no where to be found. Where can I find some more for purchase? I've tried Amazon and Google and so far no luck on finding a match that I can purchase.
picture shown is from the web but those are the discs I need
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Those are metallic dome switch critters. You can find suppliers on line. Without one to measure, finding the right ones may be challenging, ideally you need to know diameter, height and the amount of force needed to 'click' it. I couln't find any of that info for your device but it is probably available some place I didn't look. You have alternative solutions. The cheapest I found was an $19 replacement non-Jeep remote. Refurbished at $40. Which is comparable to new low end knock-off remotes. An auto dismantler may have one but their price might Not be competitive to other options considering your easiest fix would only need parts from it. Look for a source near you, an example possible source is this Not recommending, just an example. Good Luck! Edit:. These parts are dirt cheap so trial and error might be an option depends on your patience and finances. There are assortment bags and kits but no guarantee the ones you need will be there. Some manufacturers will send samples as well. I Kept looking and found this page with universal repair kits. You might also find folks in the businesses section here that supply them too.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thank you!!!
door Deel
You're quite welcome
door Deel
I'm curious, which solution worked for you?
door Deel
Voeg je antwoord toe
wrenda witt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 656
