xbox with a error code 07
i have a og xbox with a error code 07 red and green blinking light both fans are loud DVD drive wont open its says your xbox requires service 07
Is dit een goede vraag?
https://www.youtube.com/watch?v=VSrRaA6M...
This is the fix.
Any more problems ask in the comments of this answer.
Was dit antwoord nuttig?
From what I have seen, possible causes for this error are a failed hard drive, insufficient voltage to the hard drive, failed/loose IDE cable, incorrect jumper settings on the drives, or even a failed DVD drive in one case.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 47
Altijd: 780
4 opmerkingen
Is this an original Xbox?
door Andrew S
@andrewsawesome Yes, og means original.
door NR26
Can you disassemble the Xbox and upload a picture of the circuit board? Voeg afbeeldingen toe aan een bestaande vraag
door Andrew S
@andrewsawesome I'm not the person that asked this question.
door NR26
