Ga door naar hoofdinhoud
Als deel van Google's derde generatie Pixel-telefoons, is de 3a het budget-gerichte model met dezelfde camera als Google's meest populaire modellen. Beschikbaar in spierwit, gewoon zwart, or paars-ig. Uitgebracht in Mei 2019.
70 Vragen Bekijk alle
Replaced screen and now it doesn't display anything.
Hello everyone,
I just replaced the broken screen on the Pixel 3a (not my first) and now it turns on, but the screen just flashes. I notice when I touch the power button the screen flashes and nothing else.
Could I have damaged the display pins? The original screen doesn't even work now.
Edit: Posted some photos of the display connector on the motherboard for reference.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Unfortunately, it would seem that you have damaged the connector on the main board. For microsoldering repairs, @flannelist may be able to help you further.
Was dit antwoord nuttig?
Score 1
9 opmerkingen:
I figured as much, so now the next thing I would like to ask is there any way I can extract the data from this phone?
Google assitant is turned off, USB debug is also off, and I only have the fingerprint button, power button, and volume keys.
door
@troubleshot If you happen to have Google cloud backup turned on, you can get that. Otherwise, you could desolder the storage chip from the main board and solder it to a known working Pixel 3a
door
Unfortunately I had it turned off because it got full. Is there someone here familiar with microchips to see whether or not the connection is damaged.
I can get close enough with one of my better cameras. I just ordered a new screen I think it was a defect because it just flickers when I push some buttons or the screen changes to a different one. Worst case scenario I will take it to a microsolder.
door
@troubleshot I'm not that well-versed on microsoldering, but @flannelist may be able to help.
door
Thank you very much for your help. I'll try to reach @flannelist.
door
4 commentaren meer tonen
Voeg je antwoord toe
F G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 385
