Why wont my phone recives any signal?
After a hard fall my iphone on sparadicly recives any sort of signal, 3g or network. What would be the most likly cause of this?
Is dit een goede vraag?
Two main reasons this has happened
- Loost antenna connection due to impact force
- Damaged logic board
If the antenna has become loose, all you will need to do is remove the back cover and re-seat. If the logic board has been damaged then you will need to take your phone to apple and request for a replacement.
Was dit antwoord nuttig?
usually a loose antenna
you can change your sim card and try it .if that your cellphone doesnt work ,maybe it was broken.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 779
2 opmerkingen
Seeber, can you tell us which iPhone you have?
door Phillip Takahashi
i have the iPhone 4 first gen.
door seeber
